JK Wheel Spacers
Old Nov 17, 2013 | 06:45 PM
garrettuecker's Avatar
Default JK Wheel Spacers
I have a 2009 Sport X and was looking to make it look a little wider. I looked and saw wheel spacers. Are they safe to use? Will they cause parts to wear out? Any alternatives if those aren't any good?
Old Nov 17, 2013 | 06:50 PM
nthinuf's Avatar
The Spidertrax type of spacers are fine. Assuming you install them correctly and are willing to check them as part of regular maintenance.
The alternative is new rims with less backspace.
Spacers will not cause any more wear than rims with equal backspace.
Old Nov 17, 2013 | 06:52 PM
jaker t5's Avatar
Never heard of spacers on a jk , did you try the search to see if anybody else ever ran them
Old Nov 17, 2013 | 07:05 PM
catahoula's Avatar
X's 2! Do not get the cheepo washer spacers. I've been running for several thousand miles. No problem.
Old Nov 17, 2013 | 07:39 PM
Ok, thanks, if I decide to go that route I'll definitely go for the quality ones
Old Nov 17, 2013 | 07:41 PM
karls's Avatar
Clever- kudos to you fine sir :thumb:
Originally Posted by catahoula
X's 2! Do not get the cheepo washer spacers. Check out Project-JK for write up. I've been running for several thousand miles. No problem.
"Cheepo washer spacers" are perfectly acceptable so long as there is enough wheel stud for the lug nut to engage and the wheel sits flush with the mounting surface. They are prone to cracking if overtightened but that's easily avoidable.
The spacer phenomenon comes down to proper installation and maintenance by the operator. Seat belts are unsafe as wheel spacers if not installed and utilized properly.
Sent from my DROID4 using Tapatalk
Old Nov 17, 2013 | 07:50 PM
catahoula's Avatar
I still would not use.
Old Nov 17, 2013 | 07:58 PM
gunbo75's Avatar
If you want to run wheel spacers Spidertrax are the best.
Old Nov 18, 2013 | 05:46 AM
Jeepnut67's Avatar
Post I have the RC ones....
no problems at all in the 2 years I've had them on. I did use blue loctite when I installed them
Old Nov 18, 2013 | 06:04 AM
Huntphreak's Avatar
I have a 2009 JKUR, I've run bolt-on spacers for over 95,000 miles and 4 sets of tires up to 35's with no issues. Use red lok-tite when you install them and, barring some structure issue in the aluminum, or poor machining of the spacers you are good to go. I have never torque checked my spacer since I installed them almost 5 years ago. The reason for not torque checking them, as some have suggested, is to keep the integrity of the lok-tite.
