Clicking noise in front end (HELP)
Old Nov 18, 2013 | 06:20 AM
JK yeti's Avatar
Default Clicking noise in front end (HELP)
So here's the deal, running 3.5" lift, 35's
Dana 30, gusseted, trussed and just put some synergy BJ's in about 2 months ago.
So the click only happens when I'm turning slowly either direction. And it's a consitent click. So I thought maybe ujoints? How do I check the u joints?
Could it be somthing with the BJ's?
It's comming from the driver side.
Already torqued all suspension components.
Also pulled the front DS to count that out. Any help would be great!
Old Nov 18, 2013 | 06:31 AM
mjbjw's Avatar
Does the noise change with rpm?
If you suspect th we front axle shafts...put a paint mark on the end caps to see if the joints are shifting..if so they are bad..check all backing plates for lnterferance..if you changed the ball joint you had those off recently.
Old Nov 18, 2013 | 06:41 AM
Patman's Avatar
If lift is new, may be quick-disconnects. Mine move and click sone while turning
Old Nov 18, 2013 | 07:44 AM
JK yeti's Avatar
Don't have quick disco's but good thought!
Old Nov 18, 2013 | 01:26 PM
JK yeti's Avatar
Checked the U-joints and they look fine.
Next thing is I'm gona pull the axle shafts and see if it's still clicking
Old Nov 18, 2013 | 05:19 PM
hooper's Avatar
Also check for a nail or a rock wedged between your tread. A buddy had a light click that sped up while driving and it was a nail.
Old Nov 18, 2013 | 05:46 PM
Smashboogie 4x4's Avatar
Former Vendor
If you remove the axle shafts and try to drive it you will ruin your wheel bearing. You need to have at least the stub shaft installed to hold the wheel bearing together. In order to do this you need to take your shafts apart. When you do that you mind as well just replace the u-joints cause it doesn't make sense not to.
The noise is probably a dried up u-joint. Even if the caps aren't moving the needle bearings could be washed out, if you drive through water a lot, or they could be just dry.
Old Nov 19, 2013 | 04:52 AM
JK yeti's Avatar
Originally Posted by Smashboogie 4x4
If you remove the axle shafts and try to drive it you will ruin your wheel bearing. You need to have at least the stub shaft installed to hold the wheel bearing together. In order to do this you need to take your shafts apart. When you do that you mind as well just replace the u-joints cause it doesn't make sense not to. The noise is probably a dried up u-joint. Even if the caps aren't moving the needle bearings could be washed out, if you drive through water a lot, or they could be just dry.
Really? I converted it from 2wd to 4wd a couple months ago and I actually used the 2wd axle Dana 30 hub on my new 4wd Dana 30. And those hubs never had axle shafts holding them in place for the over 60,000 miles.
I put it up on jack stands and tried to remake the sound but couldn't get it to happen so that got me thinking maybe it's a load/binding issue.
I'm going un torque and retorque all suspension bolts with the JK on the ground.
Old Nov 19, 2013 | 09:29 AM
Former Vendor
I apologize but you are correct. Just have so much running through our heads all the time that we forgot about the different bearing design used on the jk as opposed to the previous d30 bearings. My mistake!
Old Nov 19, 2013 | 09:35 AM
JK yeti's Avatar
Haha no problem! But it was a good thought!
