Springs to actual height
Old Nov 20, 2013 | 02:11 PM
Dan5677's Avatar
Default Springs to actual height
So I just installed four inch skyjacker coils on my 2012 four door jk. After the install I was disappointed; it looks like all I got in height was an inch or two max. I took measurements before and after (that is how I know). The question I have is this common? I am looking for any advice or suggestions as this would be greatly appreciated.
Old Nov 20, 2013 | 02:23 PM
karls's Avatar
No, that is not typical. If you've got a bunch of weight on the jeep then you may see .5-1" less than advertised but typically the lifts are spot on or even higher than advertised.
Sent from my DROID4 using Tapatalk
Old Nov 20, 2013 | 03:04 PM
hooper's Avatar
I would call their tech/customer service.
Old Nov 20, 2013 | 03:28 PM
Rita Wrangler's Avatar
Can you use a spacer on top of the coil without the isolator?
Old Nov 20, 2013 | 04:38 PM
Ryan0260's Avatar
Did you add additional weight when you lifted it? Most springs I have used actually netted more lift than advertised initially, then settled some.
Old Nov 20, 2013 | 04:39 PM
Ryan0260's Avatar
Yes you can.
Old Nov 21, 2013 | 05:28 AM
Dan5677's Avatar
I removed a teraflex 2.5 and that gave me that height. Theses skyjackers dis not and for weight front bumper is light and I have a ebay tire carrier that does way some.
Old Nov 21, 2013 | 05:30 AM
Dan5677's Avatar
No added weight still the same bumpers and there is no way that I got 4 " in height
Old Nov 21, 2013 | 05:35 AM
ScottW's Avatar
So are you saying you got an additional inch over the height you had with the Teraflex 2.5" kit?
Old Nov 21, 2013 | 06:09 AM
GJeep's Avatar
They may have sent you the wrong coils...
