$2900 For a gear swap?
So based on my googling and digging through the forums here, I was reading that a 4.56 or 4.88 gear swap should be right around 1,000 to 1,500 dollars. I asked a local shop how much it would cost and they came back with $2900! I've copied and pasted the email below, but it sounds to me like they're trying to gouge me, and i havent gotten a response back yet on exactly what that 2900 dollars entails.
Their response
and my last reply to them
Any input would be great.
Good morning,
My girlfriend and I are talking about going to 35" tires and were wondering if you would recommend 4.56 gears or 4.88, and could quote us on an install.
While it wont be a daily driver I still need to take it on the highway and have it be able to function properly without sucking down all the gas in the world. I guess im looking for a "happy medium"
between on and off road, but leaning slightly towards off road. I just need to be able to get to about 80mph without driving the thing crazy.
Very Respectfully,
FC2(SW) French
CS/CF
USS Mason
"Proudly We Serve"
Very Respectfully,
FC2(SW) French
CS/CF
USS Mason
"Proudly We Serve"
How many miles are on your Jeep and does it have a manuel transmission? You will be right at 2900 installed for front and rear gears.
Please let me know if you have any questions.
Right around 30k and manual. Do you guys warranty that sort of work, and what does that include? That’s way more then double what ive read on several forums
I paid $1800 for mine including complete rebuild kits. I only went to 3:73's. Reason it cost $1800 was because the only rear 3:73's they could find were Mopar and they were more expensive.
What difference does it make whether you have an auto or manual. The only difference I see is that you would need a Procal if you had an auto, but you're gonna need it anyway for the 35's.
$2900 seems way high.
I paid $1800 for mine including complete rebuild kits. I only went to 3:73's. Reason it cost $1800 was because the only rear 3:73's they could find were Mopar and they were more expensive. What difference does it make whether you have an auto or manual. The only difference I see is that you would need a Procal if you had an auto, but you're gonna need it anyway for the 35's. $2900 seems way high.
My local shop is the same. They charge 1200 an axle. They replace all the bearings and seals but its still pretty high. The local drive line place in my area told me 500 if I pull my axles off and pull out the shafts and bring in the axles.
Sounds a bit pricey to me. My dealer quoted $2,400 but the local 4x4 shop quoted $1,800. The $1,800 price included Yukon gears and overhaul kits with 90 day warranty on labor. I'm not sure what the dealer was supplying. Both were 4.88.
I decided to buy Motive gears and rebuild kits as a package deal for $600. I'll do my own gears and save $1,200, thank you very much. Plus I'll have the satisfaction of knowing they are done right. I'll take however long it takes to get the shims perfect. Ok, actually I've already spent $850 of the $1,200 on TrueTrac lockers to replace the front and rear open differential carriers. That still leaves me with $350 for air compressor, impact wrench and sockets.
Write ups:
https://www.jk-forum.com/forums/jk-w...gearing-82262/
https://www.jk-forum.com/forums/modi.../begins-78112/
Write ups:
It is not uncommon to see quotes up around 3k from folks out there on the east coast, while some shops in Texas and California are doing gears for around 1k. Guess it is so high just because people are stupid enough to pay it without checking around for better quotes.
Call around and see what other shops are charging, and be sure to try and find reviews on the shops as well. You could also scroll down to the Staging Area, and post in your local subforum to see if you can find some local people who can point you at a good shop.
