Lowest Tire deflation
Ive run as low as 7-8 PSI on the beach in the sand, off road trails I run about 17-20 PSI, and for slow rocky trail (Rubicon Trail) I run 10-15 PSI. Its going to depend on vehicle weight, tire load rating/size, and rim width of what the lowest you can run is going to be. The pressures I've listed were run on TJs and my JK with various tires/wheels. You'll just have to play with the pressures on various terrians to see what works best. HTH
Got about 900-1000 miles offroad this year at 12-14psi. Granted the nitto tg is a e rated tire so doesn't flex a lot. Edit tcdawg is right. I have a jku running 35x12.5x17 nitto tg that are e rated 10 ply
I run Goodyear MTR's 37 x 12.50 on a 17x8 wheel. Run 10 psi without busting beads.
7-8 psi is what I always run. 35" mtr-k's. I've burbed a bead a few times but never lost one. I wheel 99% rocks, and with hydro you can turn into the sidewall and roll the bead fairly easily.
Risk of unseating a bead has everything to do with the wheel you run, not the tire. The wheel needs a decent raised inner bead and flat land after it. Wheels that have lower beads and/or v down into the center of the wheel make mounting a lot easier, but can lose the bead easier.
One of the guys we wheel with changed from a shallow v steel wheel that had a decent flat land to a deep v aluminum and lost 2 beads the first day out running 12 psi, which is 4 psi higher than he normally ran. FWIW.
