Suggestions needed to install winch on stock bumper.
Old Dec 19, 2013 | 07:43 AM
TakeABackRoad's Avatar
Default Suggestions needed to install winch on stock bumper.
Curious if any of you installed a winch on a stock bumper. Did you get a winch plate or modify the bumper? Or am I better off saving up for a new bumper? Mine is stock with the exception of cutting the ends and capping them.
Was trying to go with a cheap solution that works.
Old Dec 19, 2013 | 07:52 AM
Maertz's Avatar
my buddy used a winch plate and it worked fine, but id rather save for a front bumper. Depends on how much you plan to modify your rig and how hard you offroad.
Old Dec 19, 2013 | 07:59 AM
Dirt Racer 35's Avatar
How are you looking to mount it? on top of the stock bumper or hidden behind with just the fairlead sticking out. I recently did mine hidden behind the stock bumper, dont pln on doing a aftermarket bumper anytime soon, need a good lift before i do any of that. just adding the winch dropped my stock suspension 1/2"-3/4" in the front.
Old Dec 19, 2013 | 10:07 AM
Did you do it hidden behind the stock bumper using the thread on here or you just winged it? I was going to to a top mount and just get a plate but the plates are almost as expensive as bumpers on some sites.
Just looking to do a lift and not modify it too much. I commute 2 hours a day in mine. What plate did he use? That's my debate since some plates cost almost as much as bumpers
Old Dec 19, 2013 | 12:15 PM
Nibsirb's Avatar
ID:	517870Click image for larger version
ID:	517872Click image for larger version
Fairly simple mod, I knocked it out in my apartment parking lot in about a day. I used a combination of threads to do mine….see if I can find 'em for ya…..
I used a winch plate from Harbor Freight…wasn't expensive at all. Just took a little ingenuity to bring it all together...
Old Dec 19, 2013 | 12:18 PM
Nibsirb's Avatar
https://www.jk-forum.com/forums/jk-w...y-bumper-2001/
Old Dec 20, 2013 | 04:39 AM
I used ideas from the thread on here as well as winged it. I'm pretty handy, we build our own dirt track racecars, so I had some materials laying around that I was able to use. I actually mounted mine right side up hidden behind the bumper.
Old Dec 20, 2013 | 05:07 AM
Maertz's Avatar
It was a rugged ridge one i believe.
Old Dec 20, 2013 | 05:12 AM
jadmt's Avatar
JK-Forum Ambassador
you can get a rock hard 4x4 winch plate from 4wd.com for about $140 and easy to mount and solid.
Old Dec 20, 2013 | 07:27 AM
Nibsirb's Avatar
$140!!!! That's crazy talk!!!! Harbor Freight badlands universal plate.....$43.
