lift installed and rancho exhaust pipe and now have rattle
Old Dec 21, 2013 | 07:19 AM
capjim's Avatar
Default lift installed and rancho exhaust pipe and now have rattle
Ok has anyone had an issue with their exhaust rattling after lift?? sounds like my exhaust pipe is hitting the frame somewhere at certain rpms I have a 2.5 flex and the rancho head pipe. I can't see where it would be close enough to anything to make the noise and it only does it under load (so I cant rev it up on a lift and make it happen)
Old Dec 21, 2013 | 05:32 PM
Rubi-newby's Avatar
Are you sure it's not a loose heat shield. When I did my exhaust I had a rattling noise at certain rpm as well. It sounded like it was right below the driver seat. Turns out the heat shield that is above the muffler was actually sitting on the muffler. Remove shield rattle gone.
Old Dec 21, 2013 | 06:03 PM
k0260's Avatar
Check your heat shield on your cross over section of your exhaust, right in front along your cross member. The tack welds are very prone to breaking, pry on it to see if any are broken. If so, a band clamp or two will fix ya up. This is a very common source of rattles at low rpm's under load.
Old Dec 26, 2013 | 07:10 PM
capjim's Avatar
again....jk-forum answers are the best!......heat shield was loose....must have been when the guy was welding up the new exhaust pipe....right as rain now!
Old Dec 26, 2013 | 07:34 PM
k0260's Avatar
Great to hear Mine's broke in two places
