Rear Wheels not Right
Old Dec 22, 2013 | 01:22 PM
xkid's Avatar
Default Rear Wheels not Right
Hi guys,I was out doing some last minute shopping. When I came out of the store I noticed the left rear tire is sticking out farther than the left rear. Is this a rear track bar thing,or what?
Old Dec 22, 2013 | 01:25 PM
Sporticon's Avatar
If it's lifted, pretty much
sent from the slow lane
DannyMalkin's Avatar
Probably track bar. You could get a relocation bracket or an adjustable track bar.
Old Dec 22, 2013 | 01:32 PM
xkid's Avatar
Thanks guys. It's lifted 2.5 inches. Is it safe to drive in town for a day or two though?
Old Dec 22, 2013 | 01:41 PM
Jeepstin12's Avatar
Safe to drive a little. No real issue. Lots of people run it that way indefinitely.
Old Dec 22, 2013 | 01:45 PM
xkid's Avatar
Thanks again. I'm going to get it fixed ASAP.
Old Dec 22, 2013 | 01:50 PM
Rita Wrangler's Avatar
If the rear is out the front probably is too
Adjustable track bar is easy to install
Old Dec 22, 2013 | 01:55 PM
kjeeper10's Avatar
Vet Army
Axle side raised bracket.... Yep
Old Dec 22, 2013 | 06:01 PM
xkid's Avatar
Thanks again guy's.The front wheels look fine.Even.Will check the front track bar also. Is there a way so this will never happen again? Will this Axel side raised bracket,do it?
Old Dec 22, 2013 | 06:15 PM
Maertz's Avatar
depends if you change your lift... and adjustable track bar will fix almost all scenarios.
