Metal cloak 2.5 on 37s
o if thats the case you will be fine, i dont have any pictures, but ive seen plenty of people on that set up. The 2.5 and 3.5 coils are also the same length so flex wise you should have no problems with either coil. Personally i was debating switching to there 2.5s
just wanted to make sure for I drop the cash on them
What is the difference in the lift height given the above?
The Coils are set to maintain an advertised amount of lift on a fully equipped jeep. I have not seen a case where anybody got less that 3'' out of the 2.5. So unless your jeep is unusally heavy for some reason I would expect 3-3.5 out of the 2.5 coils.
