Fox ATS steering Stabilizer or Bilistens?
ATS
It's a whole kit that mounts above the tie rod to the track bar/bracket.
Bilstein shock + tie rod mount + track bar mount = close to what the ATS cost.
Worth every cent more
personally i wouldnt run one and save the money for a diy hyrdo set up (could even cost less) i havent ran one for quite awhile and have all the parts i need for hydro except the ram.
If i had to run one i would probably get the ats as The bilstein without moving it would get destroyed in one trip out.
Believe everything you read about it. Thought it was way too expensive, but if it broke tomorrow, I would order another within the hour. The adjuster feature is immediately noticeable. One of my biggest complaints is the bigger the tire I went with, the less it drove like stock. I know... it's a Jeep. But selfishly, I wanted tighter steering (reduce the loose feel). The Fox made a huge difference. Steering much tighter... but I do run it down around 20+ clicks. It's just a personal thing.
I do agree that a stabilizer is not needed. Whenever I do any work on the front end, I remove the stabilizer for a few days. Want to make sure everything is right and stabilizer is not covering up a problem. But the "dampener" part is what I am jazzed about. Totally recommend. And I took off a Bilstein to do the ATS. Zero comparison with that adjuster on the Fox.
