Jack stand suggestions?
Old Dec 30, 2013 | 11:15 AM
Born To Die's Avatar
Default Jack stand suggestions?
Looking to purchase some new jack stands for my 08 JK. Any recommendations, or insight on what weight stand I should be looking for? Thanks
Old Dec 30, 2013 | 11:20 AM
JK08MCS's Avatar
How big a tire and lift you running?
Old Dec 30, 2013 | 11:21 AM
OEM right now, putting a 2" lift and 33" tires on.
Old Dec 30, 2013 | 11:22 AM
jadmt's Avatar
JK-Forum Ambassador
harbor frieght 6 tons work great and with a coupon can be had for dirt cheap
Old Dec 30, 2013 | 11:26 AM
Great, I'll check them out. Thanks!
Old Dec 30, 2013 | 12:03 PM
JK08MCS's Avatar
X2 on the 6 tons work great for my rig
Old Dec 30, 2013 | 12:20 PM
JLsJK's Avatar
Tractor supply has some useful jack stands that have a bottle jack built into them. I bought 2 of those. I think they were 29.99.
Old Dec 30, 2013 | 01:04 PM
DanNEBTD's Avatar
^^This, I love these and they are compact/convenient. just remember that after the stand is at a proper height to back off the pressure to the jack so the weight is securely on the stand it'self . . . same as you would a normal jack.
Old Dec 30, 2013 | 01:28 PM
nthinuf's Avatar
The tallest and beefiest stands you can find.
I am much happier with the 24" tall 6-tons from harbor freight than the 16" tall 3-tons they replaced. And even if you don't need the extra height, you will feel safer underneath a 24" stand only raised to 16" than under a 16" stand raised to full height...
Old Dec 30, 2013 | 01:35 PM
jadmt's Avatar
JK-Forum Ambassador
absolutely. I first bought the 3 ton stands for my jku and it looked all spindly up on them so I took them back and got the 6 ton ones. 2 sets jku completely off the ground and solid as a rock. Sure they 3tons probably would work but I figured my comfort level wrenching underneat it raised off the ground was worth a few extra dollars. the 6 tons are like $30 a set wtih a coupon that can be found in any off road magazine
