Lockers
Old Dec 31, 2013 | 10:10 AM
livewire0212's Avatar
Default Lockers
I recently installed Dana 44 rubicon axles of a 11 rubicon onto my 09 unlimited. They have 4.88 gears & rubicon electric lockers. Everything went good, I am having a heck of a time with the rear locker unlocking?? T
It's straight wired pos neg & power to the switch. Not sure why it's having so much trouble unlocking??
Old Dec 31, 2013 | 10:47 AM
ronjenx's Avatar
Did you keep position plunger in the system?
If so, did you install it after the carrier went in?
Installing it after the carrier will cause the locker to stick in the locked position.
Old Dec 31, 2013 | 10:55 AM
courtsm3's Avatar
Originally Posted by livewire0212
I recently installed Dana 44 rubicon axles of a 11 rubicon onto my 09 unlimited. They have 4.88 gears & rubicon electric lockers. Everything went good, I am having a heck of a time with the rear locker unlocking?? T It's straight wired pos neg & power to the switch. Not sure why it's having so much trouble unlocking??
Off topic, but how easy/hard was the install? Found a cheap front rubi 44. Thanks
Old Dec 31, 2013 | 12:47 PM
Roryslife's Avatar
It's easy to remove replace axles. 1/2 a days work. Should bolt right back up.
Old Dec 31, 2013 | 04:05 PM
Everything was all in when i got the but definetly will check that!! Thanks!! It was not to bad for bolting everything up the front went great!!! The rear was a lot more work!!
Old Dec 31, 2013 | 04:17 PM
ronjenx's Avatar
The position sensor needs to be hooked over the lock plate as shown in this picture.
