Fire Extinguisher mount that can be reached from the drivers seat...
well the subject says it all...
i've got a decent one now but its attached to a roll bar where it could take me a while to get to it in case of a real emergency
i tried searching but nothing mentioned mounting within reach
matthew
matthew
i don't recall seeing that setup before...
I'm going to look into it
matthew
Attachment 521784 This Extinguisher came with a mount that bolted right to the seat rail.
im leaning towards the drake one as it uses a big red button, so if someone else is around who needs to get access quickly it's totally self explanatory!
matthew
It's a H3R Performance HalGuard HG250B Clean Agent Fire Extinguisher. It comes with the mount and is also something you can use inside the vehicle without damaging electronics and nothing to cleanup. It's expensive but worth the money if you ever have to use it.
