What Tie-Rods use GM 1 Ton TREs?
Old Jan 4, 2014 | 03:29 PM
Gossamer's Avatar
Default What Tie-Rods use GM 1 Ton TREs?
I have an axle that I picked up from a forum member and it currently has the Ruff Stuff Tie Rod with GM 1 Ton TREs on each end which also means that the knuckles have been reamed for those TREs. The Tie Rod came bent inwards from the previous use so it hits the welded on trackbar bracket so I need to replace it. My problem is that the knuckles are reamed to fit the 1 Ton TREs so I am limited on my replacement choices.
I am not sure how hard or what force it took to bend the tubing however I am looking to replace it with a more stout option if possible. Plus I do not have a welder to be able to replace it with the same build it yourself one.
Thanks,
Rick.
Old Jan 4, 2014 | 04:30 PM
jaker t5's Avatar
Most off the guys who run that tie rod did not have to ream the knuckles and that includes me
So make sure first if it did get reamed
Old Jan 4, 2014 | 05:05 PM
Gossamer's Avatar
Unfortunately it is reamed with inserts, figures with my luck...
Rick.
Old Jan 4, 2014 | 05:35 PM
07sgt0720's Avatar
This might help.
Offset Tie Rod Kit - RuffStuff Specialties
Old Jan 4, 2014 | 06:54 PM
jeep-rat's Avatar
Carolina Metal Masters makes a Tie Rod similar to the Ruff Stuff except that it is Aluminum. Uses the same offset TRE. I went to this after bending the Ruff Stuff Tie Rod. Steering Tie Rod | Carolina Metal Masters
Old Jan 5, 2014 | 03:56 AM
Gossamer's Avatar
Originally Posted by 07sgt0720
That is the one that is currently on my rig. I am looking for other options to replace it with if possible. Maybe aluminum.
Thanks,
Rick.
Old Jan 5, 2014 | 03:38 PM
Gossamer's Avatar
I was just eying this one. Where did you pick yours up from? Was there a long wait?
Thanks,
Rick.
