What other parts should I order with my RK lift?
Old Jan 7, 2014 | 01:12 PM
AR15gunner's Avatar
Default What other parts should I order with my RK lift?
Northridge currently has 20% off their Rock Krawler stuff, so I'm going to order my lift soon. I'm probably going to just go with the 2.5" Stock Mod system for now, but I was curious what other parts I should order with it, since they're on sale. I was thinking I should get the front coil spring clips and the rear coil spring correction wedges, bump stops and maybe the stainless steel brake lines, but is there anything else I should order right now (aside from one of their higher end lifts)?
Thoughts on this lift? The only issue I see is that I have a Rubicon and wouldn't need the sway bar disconnects, because I'd like to keep the factory ones.
http://www.northridge4x4.com/shop/ro...m-rkjk25fs-kit
Old Jan 7, 2014 | 02:05 PM
TOTL Innovations's Avatar
Former Vendor
You will need longer sway bar links at the least anway to account for the lift.
Old Jan 7, 2014 | 02:16 PM
olram30's Avatar
just buy that kit you gave a link to and throw in a front drive shaft also.
Old Jan 8, 2014 | 03:00 AM
AR15gunner's Avatar
I thought a front drive shaft was only needed on the JKU if you went with a 3.5" or taller lift.
Old Jan 8, 2014 | 04:22 AM
bluebear's Avatar
Just know you won't get 20% on the kit you linked.
Old Jan 8, 2014 | 04:40 AM
AR15gunner's Avatar
I realized that after I posted it. It looks like it was already taken off the RK stuff, possibly some of the other parts. I haven't done the math.
