Question About Track bar and Drag link
Old Jan 7, 2014 | 04:59 PM
WhiteWidow13's Avatar
Default Question About Track bar and Drag link
Im running a rough country 3.5" lift and it came with a drop pitman arm and a track bar bracket to relocate everything correctly. i just purchased an adjustable track
bar and a new heavy duty drag link and was wandering if i remove the track bar bracket and install the adjustable one in the stock location and install the stock pitman arm with the new drag link would this cause bump steer? or do i need to keep the drop pitman arm or the trackbar bracket?
Old Jan 7, 2014 | 05:16 PM
Croce's Avatar
I have the same kit. With an Adj. trackbar you dont want to use the drop pitman arm or trackbar relocation bracket, just replace the stock one with the adj. one and then center your axle
Old Jan 7, 2014 | 05:21 PM
okay sweet. thats what i was wandering. you dont have bumper steer or any issues with it do you?
Old Jan 7, 2014 | 05:26 PM
Croce's Avatar
Nope, i actually had to purchase an adj trackbar because the bump steer was so bad. I couldnt get the drop pitman arm off so i was just using the stock trackbar and relocation bracket originally which is probably what caused the bump steer
