Clutch pedal
Has anyone else experience there clutch pedal release really high almost to the point where it's all the way out before it grabs. I mean it's not slipping or anything but just releases really high. The tranny still shifts smooths and has no problems in any gear. Fluid is all good and where it need to be also checked the slave no leaks.
Any help would be appreciated
I'm having the same issue with my 09 rubicon. Bought it used and it was like that when I got it. I hate it!! Going to let a shop check it out this afternoon. If they can figure it out I'll repost and let you know. If not I'm seriously considering purposly smoking that clutch and replacing it.
When you bleed it did you just open and close a few time or do you remove a lot of fluid?
