Front Upper CA Bushings
Who makes good replacement bushings for the front upper control arm on the axle side?
Any write-ups or tips?
As with most questions a little more info on how you plan on using the rig would be helpful in making suggestions. Johnny joints are great joints if you are planning on a lot of off road and less on road due to the loss on cushioning that the OME rubber bushing gives. There a number of companies out there who make comparable joints and then there is also the Metal Cloak duroflex joints, they will give you a compromise between the two with a high level of mis-alignment capability with the cushioning that comes with the primarily rubber joint that is the factory unit. I'm currently running both joints in my rear lower arms, I chose them for their individual qualities; the JJs for their flex, and the MCs for the flex and some of the factory like dampening that they provide. I'm not sure if they make that specific joint for the front upper application though, you may need to call Matson and ask them if they have a solution for that. Good luck!
![beer](https://www.jk-forum.com/forums/images/smilies/beermug.gif)
Besides the factory clevite bushings, your only other options are JJ's for the fixed axle UCA bushings. Either the kit directly from currie, or Polyperformance's kit using JJ's.
I went with the Currie kit for their thicker passenger side replacement tower, which works will with the Artec truss.
The two JJ kits require cutting and welding. Replacing the factory requires just a press and some time.
