Beginner Question -- Motor Oil and Filter Brand Preference
Looking for opinions on which brands owners use for their JK's. Mine is 2010 stock.
Thanks for your help. akk
Wow, are you opening up a monster thread. Hold on to your hat when the responses start rolling in. Try searching the forum on oil and filter recommendations. My advice, use what you want that meets OEM specs. Watch oil consumption and have fun. Welcome
Edit: I should have specified for the 4.2L Ford motor above.
The 1998 F-150 oil filter is a perfect match for the 3.8 motor, except it is physically longer. It fits fine, and has the correct back pressure relief valve. In fact, I have mine on a Glowshift sandwich plate for an oil pressure sensor--still room left. I currently use Napa Gold filters, which are actually Wix filters. I use Mobil 1 Extended Life motor oil--5W-30.
Jeep forums, motorcycle forums, tuner car forums, there's always an oil thread. If you're going to start one, have flame retardant underwear, cause it's gonna get hot. Lol.
Any spec 'd oil will suffice. Ditto with filters. Read around on different review sites, search here, make your own choices based on that.
I've heard of doing this, does it cause any issues with oil pressure or anything? Also given that the filter is larger and holds more oil could that create issues with having enough oil at a given time because more oil is in the filter as opposed to flowing through the engine?
I have 133K miles running these larger filters. And do monitor the oil pressure ...
Sent from my obama monitoring device
Honestly, 9 times out of 10 the oil you are running won't matter, so long as you change it on a regular basis.
I have only run Mobile1 in the last few vehicles I've owned, never had a problem.
