Rustoleum Bed Liner HELP!
I just used this stuff on my newly made rock rails and front bumper.
The bumper and rails were RAW metal.
I prepped using everything i read.
-washed parts with simplegreen to clean/degrease.
-sanded parts lightly
-wash again with simple green using a green scotch bright pad
-rubbed down with alcohol and sprayed hard to reach parts with brake cleaner.
-hung them up, and used a tach cloth before first coat.
-Sprayed light even coats
-Sprayed about 4 good coats waited 20 min inbetween coats
-let "cure" about 20 hours before i installed them
only thing that i couldent help was that i painted them on a day that it was 55-60 deg out. This was the warmest day by far this winter and was the best sunny/warm day to do it outside. After all the coats, i took the parts in-doors to cure for the 20 hours over night into the next day.
So the stuff seems to chip pretty easy........
Did i paint them when it was to cold out and it may take longer (like days) for this stuff to cure? Or is it just this brittle.
Should i go over it with the roll-on version when i gets warmer?![Mad](https://www.jk-forum.com/forums/images/smilies/mad.png)
![naw](https://www.jk-forum.com/forums/images/smilies/icon_naw.gif)
![Don't Know](https://www.jk-forum.com/forums/images/smilies/z0tdntknw.gif)
The temp. probably has a lot to do with it. Remember if the ambient high was only that temp the metal parts were likely much cooler.
This said, I have noticed it chips off of my Aluminium PSC flares somewhat easily. So much so in fact that I now first paint a coat of flat black on stuff, and top goat with the Turck Bed Liner. Since doing this I haven't noticed anything, but then again I never had an issue on the steel parts to begin with.
Best thing to do for winter projacts like this is if they are small enough bring them in the house. If it is larger wait for the low temp be optimal for painting.
Sorry
I did not prime.
The directions as well as people on here said primer is not needed. as well as a video about the application on rustoleums website.
I dont know if the temp has that much play in it. the coats all dried with in 5 to 10 minutes to the touch, well ahead of the 20 mins the directions said it would take.
I guess ill just wait it out and see what happens in the next week or so. At worst, ill wait till a nice spring day and scuff up the high traffic areas and use the roll on version.
I've has issues with bare metal and bed liner before, no matter how much i prepped it wouldn't stick good. I used an etching primer an have never had a problem since. It makes the paint bite a lot better.
