Concerned about open diff/have BLD quesiton
I've been reading about BLD on here, but haven't been able to figure out if it's a standard feature or not. I'm assuming so, as there is no option to add it for a new build? With that said, I've found a 2014 JKU that I really like, but I just realized it doesn't have the "track-loc". Will it still have BLD? How is wheeling with an open diff (and hopefully BLD)? I do zero rock crawling here in Florida. It's mostly just flat trails, occasional mud hole, sugar sand or flat cap rock.
All JKs have Brake Lock Diffs. it's all software driven.
you must be in 4W High to turn it 'on'.
it's pretty slick.
the problem is the name... Brake Lock Differential... the Diff doesn't do anything... it's just an open diff.
by a computer finding a spinning wheel, it assumes it's lost traction, it applies the brake to it, which sends more power to the wheel on the other side of the axle through the normal action of any open diff...
so, it brakes the wheel that's spinning the fastest. it uses wheel speed sensors and your ABS, but technically, nothing ever changes about the diff... so the name is a bit misleading.
it is not a true 'locker', however under even heavy use, 75-90% of the time... Im sure it works just as well.
If your not scaling 3' boulders on 35" tires... a manually activated locker really isn't needed.
it's pretty slick.
Brake lock diff certainly works in 2wd as well as other positions- I've tried it out just to see. It is fairly effective but you need to induce wheel spin to get it to apply the brakes on the side that is spinning.
Yes. The trac-lok LSD is clutch based so you will have some spinning before it engages the wheel with more traction. When I got my 2012, I avoided the Trac-Loc option and installed True-Tracs front and rear when funds became available. Best decision I have made regarding the Jeep.
Thanks for the answers everyone. Definitely made me more at east about not getting the LSD. Seems the BLD will suffice for the mild stuff that I'll see when I'm on the trail.
![beer](https://www.jk-forum.com/forums/images/smilies/beermug.gif)
The rear axle has it all the time. The front axle has it in both 4wd modes.
