Anyone else have a 6 speed that has or had a hard time shifting into first?
Hello all! First time Jeep owner and loving it for the most part but I have a very annoying problem that could even be serious under the right conditions. I just bought a 2011 JK 2door with 6speed and there are times where I just have to keep fighting it to go into first gear. Its a smooth as butter at times like all the other gears, reverse being the only other exception but I kinda don't mind that so much. I cant always reproduce the situation but most often its while already moving. It has been unusually cold in Texas this year so but im not ready to blame that solely. Any thoughts would be appreciated! Thanks
![beer](https://www.jk-forum.com/forums/images/smilies/beermug.gif)
I have had that issue on my '01 Ranger. Turned out to be an issue with the clutch slave cylinder. I'm not too savvy on the workings of the '11 tranny, but normally slave cylinders are pretty easy to replace. Does it make a harsh whining sound when you try to shift into first, or is it simply like it is blocked? Could be a sychro issue?
That is a good sign. Whatever you do, try not to force it into gear. If you place it into second or reverse gear first and roll forwards/backwards a bit does it then go into first easier?
Mine can be a little tough sometimes as well, I've gotten in the habit of always quickly shifting into 2nd then up into 1st, and then it always goes in smoothly. Perhaps something with the 1st synchro not wanting to lineup correctly? Not sure, just know this is what has worked for me
THIS, i have a 2011 JKU 6spd, ~40,000. 2nd gear is shall i say 'shifty' when trying to engage it. not the cleanest as when i first got the Jeep 3 years ago. feels like it sticks half way through when fully engaging 2nd gear. funny this thread posted up, was going to start searching issues soon.
2013 JK and mine has always disliked going into first if I'm moving. Seems like it is over 5mph. I assumed it was due to the low first gear. No big deal.
Pretty sure that somewhere in the owners manual it states "if you can't find them, grind them"!
Don't try and shift into first if going over 5mph, it doesn't let you go in for a reason, on the other hand shifting from 1st to 2nd when cold feels like I'm driving a Model T, but I think it states that in the Jeeps Manuel as well lol.
