Drag Link Replacement - Synergy???
I've done some research but want to be 100% before I pull the trigger.
I have an '07 Rubicon w/ 35s, a 2.5" Teraflex Budget Lift, 1.25" Rough Country Body Lift, and Synergy Front Track bar. I'm getting steering wobble from left to right at approx. 40 mph then tapers off. I disconnected the steering stabilizer and had a friend turn the steering back and forth. I found the drag link joints are both bad.
My question is with my set up, can I get buy purchasing only the Synergy High Steer drag link? Or do I need to purchase the Track Bar Bracket to flip to the top of the knuckle, or will i be fine just using the tie rod flip adapter w/ the 13/16" or 7/8 drill bit?
I'll just go with the stock position.
body lift has nothing to do with your steering or suspension geometry. I run the same set up as you and have no problems. youll be pleased with the draglink its a solid piece
Synergy is a very nice drag link
Synergy Suspension Jeep JK High Steer Drag Link (PPM-8001)
uses same ends as the Tie rod also.
David
David
I got the rubicon express drag link in the stock location. It is much better than the stock. My steering is a lot more stable and has less slack than with the stock. It is not quite a strong as the Synergy but I got a unbeatable deal. Also nice that it uses off the shelf 1 ton rod ends.
