285/75/17 on stock wheels and 1.5" Spidertrax spacers
Been attempting to use the infamous "SEARCH" function. It is not working through my iPhone. I have been trying to decide between 285/75/17 Toyo A/T II tires or 295/70/17 Toyo M/T's. I bought a set of 1.5" Spidertrax spacers, as I don't want to invest in new wheels at this time. I have a 2012 JKU SPORT with 3.21 gears in 3.6 automatic. I am currently stock, no coil spacers or anything. I won't be able to lift within the next few months. This is my dd, and it will be mostly highway here in North Central Fl. If taken off-road, it would not involve rocks. Mud is a possibility if it lays ahead on the trail. Mud bogs are not in my future.
Would both these setups run without rubbing? The A/T II's would be 34", while the M/T's would be 33"'s.
Thank you in advance.
I speak from experience when I say you will rub. A 34" tire won't fit without some sort of lift. Spend the money once when you can a get a 2.5" lift. For the time being, patience is your best friend. Ive been down this road.......
the white one has 34's the silver 33's both have 1.5" spidertrax and both a/t2's. white has 2" lift the silver has 2.5" lift.
I just bought a Warn Elite with bull bar front bumper and Warn Zeon 10. I plan on mounting it this weekend. With the bumper flaring up on tire side, will it help my situation or hurt it?
I have 285/75/17 Toyo AT2 extreme tread on stock wheels. Great tire. With a Teraflex leveling kit (2" front 1" rear) and 1.5" wheel spacers absolutely no rub. As long as you don't do any major flexing I think wheel spacers and no lift would be fine. Also just fits the stock carrier with a small $15 spacer from Auto Zone. Good luck.
Sent from my SCH-I545 using Tapatalk
