rubicon express sway bar quick disconnects
Old Feb 17, 2014 | 06:59 PM
Bryanc182's Avatar
I just installed these tonight. It all took but an hour to an hour in a half. I just want to double check with anyone else out there that has a pair or something similar and make sure that I did the install correctly....and yes I read the instructions any thoughts, comments or help is greatly appreciated!!
ID:	531758   Click image for larger version
Old Mar 22, 2014 | 06:01 PM
Ricknav1973's Avatar
Default Rubicon express swaybar disconnects
I just installed mine , followed the instructions and from looking at your photos the only difference is the threaded part is on the bottom. I don't think it should make a difference. How do you like your Rubicon quick disconnects?
Old Mar 22, 2014 | 06:56 PM
Battlefrog21's Avatar
From the looks of it (may just be the angle of picture), your sway bar is not level. Not a huge issue, but if you are able to adjust them, I would..
