Rubbing with 3.25 lift with 35s
So I took it offroading after getting the new lift kit and tires and when all flexed out I rub in the back on the fenders.
Does this happen with all 2.5/3.25 lifts? it looks like I have so much room but still. I know I'm gonna have to add bump stops or get flat fenders but still I thought with this much lift I wouldn't need that
I have the rough country 3.25 kit meant for 4 doors on my 2 door. it's 2.5 coils with .75 spacers on it
Here's a pic of it level
Now here it is flexed
If you put bigger tires on your jeep you need to add bump stop or run a flat fender for the needed clearance. The lift really has nothing to do with it. All the lift does it take away droop and increase up travel, all other things being equal.
In order to run 35s with stock flares, you need 2.5" extended bumpstops.
Even with flat flares, extended bumpstops are needed in the rear to run 35s unless you are willing to cut as much as 1-1.5" or more off the rear fender well pinch seams.
The RC 3.25" lift is incomplete because it does not include extended bumpstops, adjustable front lower control arms, or an adjustable front trackbar.
In order to run 35s with stock flares, you need 2.5" extended bumpstops. Even with flat flares, extended bumpstops are needed in the rear to run 35s unless you are willing to cut as much as 1-1.5" or more off the rear fender well pinch seams. The RC 3.25" lift is incomplete because it does not include extended bumpstops, adjustable front lower control arms, or an adjustable front trackbar.
I'll also say people say it's a stiff ride, it was at first a very harsh ride but after 1,000 miles it settled down and rides better now, not harsh at all . Also this can be contributed to warmer temperatures now, Went from the single digits/teens to 50
Gotcha I just need to get bump stops now. And i know it's incomplete but so are all the other kits out there they don't give you that stuff, but for the price it's great . I added a front track bar, and I have the aev drop down brackets for the lower control arms (for now) I'll also say people say it's a stiff ride, it was at first a very harsh ride but after 1,000 miles it settled down and rides better now, not harsh at all . Also this can be contributed to warmer temperatures now, Went from the single digits/teens to 50
