Eaton jk dana 44 part number
I'm about to pull the trigger on an eaton e locker for my 11 jk Sahara with 5:13 gears. I just want to make sure I'm ordering the proper one. I don't see any place specially showing the locker for a JK DANA 44.
Is 19747-010 the old 2 pin part number and
19969-010 the 4 pin one?
Thank you
Thank you
We keep the locker in stock that fits that application. The new 4 pinion part number is 19977-010. You will need to drill out the carrier to fit the JK ring gear bolts though.
Eaton ELocker 4, Dana 44, 30 Spline, 3.73 & Down Gear Ratio - 19977-010
We keep the locker in stock that fits that application. The new 4 pinion part number is 19977-010. You will need to drill out the carrier to fit the JK ring gear bolts though. Eaton ELocker 4, Dana 44, 30 Spline, 3.73 & Down Gear Ratio - 19977-010
That will be a job for a machine shop . There are enough Jeeps on the road that Eaton should have a part that fits .
David
I have another question for you on this subject. When I install the Eaton e-locker I would like to install a set of rear axles. Does RCV offer rear axles for this set-up and do you stock them ?
I am waiting for Yates from Or-fab to get back to me on the Rotopax part numbers too. So my order should be comming your way soon, I hope .......
