Why are my mpg's so low
Okay, so obviously I don't expect great or even good gas mileage from a brick on wheels, but I just upgraded my stock sport tires for lt255/75/r17 (32 inch) nitto trail grapplers a few months ago and my mpgs dropped to 14 city and it really doesn't get much more than that on the freeways. I plan on moving up to 35s soon and getting steel bumpers but I'm a little worried about losing much more.
I have an automatic 2013 jku with a 3.21 gear ratio.
Excuse my ignorance if this is just something to be expected or if it's a very simple problem.
Okay, so obviously I don't expect great or even good gas mileage from a brick on wheels, but I just upgraded my stock sport tires for lt255/75/r17 (32 inch) nitto trail grapplers a few months ago and my mpgs dropped to 14 city and it really doesn't get much more than that on the freeways. I plan on moving up to 35s soon and getting steel bumpers but I'm a little worried about losing much more. I have an automatic 2013 jku with a 3.21 gear ratio. Excuse my ignorance if this is just something to be expected or if it's a very simple problem.
If you go with even larger tires and add more weight, mileage will drop even more. You can add a gear change into your plans ($1000-1500) to regain some lost power and mileage. The best thing you can do is go easy with the right foot.
It also depends on the roads you are driving on down there. Hills can cut into your gas mileage also.
On a side note there are 4-5 jeep clubs down there in Arkansas check them out also.
If you going up to 35's -3.21 not good for those and when you add a lift you get more Air Drag or dirty air which will cut into your gas mileage. All the trade offs of doing stuff to jeeps.
rock
