TeraFlex Budget Boost with Bilstein 5100 or King 2.5's...will the spring unseat?
Old Feb 19, 2014 | 05:06 AM
wgoode77's Avatar
Default TeraFlex Budget Boost with Bilstein 5100 or King 2.5's...will the spring unseat?
Quick question and wondering if anyone can provide insight. I'm considering the TeraFlex budget boost as an interim lift and wondering if I could put a longer shock like the Bilstein 5100's or King 2.5's and not have to worry about the spring unseating during max flex. Do I have to replace the spring with a longer one? Thoughts?
I know they sell a kit with shocks, but I wasn't sure of the length of TeraFlex shock compared to the 5100 or the 2.5's.
Old Feb 19, 2014 | 05:09 AM
jeeperjkjeeper's Avatar
I ran the TF 2.5" BB with the 5100's 1-4" with no issues unseating a spring.
Old Feb 19, 2014 | 06:50 AM
TheDirtman's Avatar
It will depend on the compressed and extended length of the shocks.
Old Feb 19, 2014 | 06:57 AM
wgoode77's Avatar
Good to hear from you Dirtman. That's the direction I need. JeeperJK, mentions he used the 5100 0"-4"...I didn't realize the shocks came in different lengths. How do you suggest I maximize my down travel and pick the right shock length (and keep the coils in place)?
Do the King's come in different lengths as well? Likely to end up with the 3" EVO plush coils, so I'd like to have a shock that would accommodate that setup down the road (without limiting downtravel with the longer spring)
Old Feb 19, 2014 | 07:01 AM
TeraFlex's Avatar
Sponsoring Manufacturer
If you buy 2.5" shocks, you should be fine. However if you get a shock that is for 2.5"-4" then the coils can unseat.
TeraFlex 2.5" shock specs:
Front 24.50" ext 15.41" compressed
Rear 24.99" ext 15.63" compressed
Old Feb 19, 2014 | 07:02 AM
TheDirtman's Avatar
You can order king shocks in any length you want. If you are looking at spending that kind of money on shocks I would get a master plan set so you get the right ones ordered.
