RC Lift Spring Sag
So I'm in the market for a Rough Country 3.5 or 4 inch lift and though I've read numerous posts from people saying not to buy them, I've also read many positive reviews from those who do have them. My needs and budget seem to point to RC as the best value however I have had one concern which seems to be a problem prevalent with their coils..Sagging.
I've contacted RC and they've told me they switched from a progressive coil to a new one about a year ago which has stopped the sagging issue. I've seen a few forum posters mention the same thing but my question is...
Anyone with a RC lift (less than a year old), have you noticed sag in the springs? I have a new front bumper, winch, rear bumper and tire carrier so the added weight will only exasperate the problem if the sagging issue still exists. If they've fixed the issue then Ill likely go ahead and purchase.
Thanks!
Thanks!
cvAnyone with a RC lift (less than a year old), have you noticed sag in the springs? I have a new front bumper, winch, rear bumper and tire carrier so the added weight will only exasperate the problem if the sagging issue still exists. If they've fixed the issue then Ill likely go ahead and purchase.
Thanks!
Thanks!
I just took off my RC on monday and put on RK coils. Yes they will sag and you will not be happy. If budget is the problem I suggest wait and save or you will have to spend twice. Believe me I spent twice.
OP- you can certainly try the RC coils if they really fit your budget and if they sag then have RC warrantee them and replace them for you. All you'll be out is your time to replace them. It's unlikely that you'll find someone who has had the coils less than a year and noticed the sag. They may be on the verge of the start of the sag.
I wish you the best of luck with your lift choice. Also, I'm not saying the RC or TF coils are terrible for sagging because the factory coils do it as well. The difference is that the RC and TF are designed for 'lift' so they should be more resilient than they are.
All coils will sag eventually at different rates than others. The big problem is consistently making coils that will break in at the same rate. I often think if its the type of metal in cheaper springs that fail??
Well if I'm guaranteed to have to purchase new springs it makes sense to move up a notch. That would likely bring me to the Procomp Stage 1 4" lift followed by the Rubicon Express 3.5" lift. Will either of those fare better when it comes to sagging. Procomp seems to be heavily dis-liked much like RC and most other budget lifts but the Rubicon Express seem to get rather positive reviews relative to their price.
I can always spend more but I really need to set a limit on what I spend with my jeep because we're in the process of a home remodel which is killing my bank account. Drive shafts, c-gussets, axle sleeves, tires, and wheels are going to be brutal so my budget is pretty much maxed at 800ish and even that's a long stretch (love to spend 5 or 6).
To be where you want to be price wise, stick with a 2.5" quality lift and add a body lift later. The taller lifts will require extra components ($$$$).
Have you read "my thoughts on lifts" by dirtman? I'm curious why you're looking for a taller lift. I advocate taller lifts but you've got to know there's serious money involved with them. "Taller" being 3.5"+, IMO.
The main reason I'm looking to go bigger than 2.5 is that I'm going to run 37's. I really don't need that big of a tire and honestly its mostly because they look fun. I had 35's on my previous jeep and 34's on my FJ and with this new jeep I want it to be different. The vehicle isn't a daily driver but I also won't be taking it to moab. Local trails and some rock would be the extent of my use so I feel the setup I'm going with should work well for me. I'm also not a huge fan of body lifts because I hate the space it creates. My previous jeep had 1.5 inches and I could never get past how it looked.
