Odd noise when accelerating after shifting into gear.
Gents, I could use some help on this one. When I shift into 2nd, 3rd and sometimes 4th gear I get a quick but noticeable squeaking sound as soon as the clutch engages. I also sometimes get the same noise when I slow down (in the same gear still) and apply a quick amount of gas. So far I have removed my front drive shaft to trouble shoot the u-joints on my drive shaft, however, the sound still remains. Could it potentially be the fan belt slipping when I accelerate or something wrong with the clutch disk? It's a 2011 2 door manual. Thanks.
Did you add a super charger + nitrous recently?? Maybe you're chirping the tires all the way through 4th!!
![Thumb](https://www.jk-forum.com/forums/images/smilies/thumb.gif)
Possibly a coincidence, but there is a new post on one of the other forums regarding a recall for 2011-2013 manual trans Jks. The issue is a squeaking when the clutch is let out and engaging. How timely!
