will a snorkel fit
I have a body armor roof rack and I'd like to add a snorkel and kc lights to my windshield hinge mount. First does anyone have all three? Do they fit? Pics? And for a snorkel what brand should I get? Every snorkel I've seen on amazon has bad reviews. Aslo I don't want to do any cutting to the body to mount the snorkel.
I'm not so sure about that. If you look at the design of the safari and placement, I don't think it will clear his rack bar...
That said, you ARE going to have to cut into the body if you plan on having a functional snorkel. If not, you can just stick anything to the side of your Jeep and call it a snorkel.
I think it does, just. I ordered that rack for my two door. The only thing that stopped it working was the fact my snorkel was already mounted and so I couldn't get to the bolts on the snorkel side. Otherwise it would have worked fine on mine. That said, you ARE going to have to cut into the body if you plan on having a functional snorkel. If not, you can just stick anything to the side of your Jeep and call it a snorkel.
My plan is a 40 or 50in flood light bar for the rack, and kc spot beams for the windshield. That's what I want to do at least.
If your referring to the low mount snorkel, there is no way I'd ever run that. Reason being, I'd be afraid of spray getting up in there and getting into your intake. Also, that area of the cowl is not fun to work with.
