Rear TB rubbing spring
Old Mar 9, 2014 | 01:19 PM
NCRUBI2012's Avatar
Default Rear TB rubbing spring
My right rear spring is suddenly rubbing the TB. It has never been an issue. Any thoughts?
2012 2 door with 2.5 TF and Fox shocks. What can I do to fix.
Old Mar 9, 2014 | 01:28 PM
JE8154's Avatar
coil correction wedges
Old Mar 9, 2014 | 01:52 PM
JKMedicPA's Avatar
Just curious cause I am new to all of this. I am running a 2014 2.5 Rough Country suspension left with OEM stocks. Since I had it all put on, theres been a weird "squeaky" bed sound, you know like an old bed creek and occasionally I will here a "squeaky rusty wheel". I went around a torqued the body mounts, tightened the rear and front bumpers, and now all that I can think is theres something wrong with my suspension. Its only in the pass side rear.
Old Mar 9, 2014 | 02:02 PM
Invest2m4's Avatar
Check the sway bar link bolts. Might be rubbing something. Also check to see if the rear upper coil isolater is there (rubber part on top of the coil).
Old Mar 9, 2014 | 02:06 PM
JKMedicPA's Avatar
Thank you sorry to steal the thread like that, just seen this and it reminded me to ask.
Old Mar 14, 2014 | 02:38 PM
NCRUBI2012's Avatar
Okay got correction wedges. Any tips on install? High side towards TB? They are so "slippery" will this not cause a problem with springs shifting or moving around??
Do I still add the spring hold downs after? Nothing in the box. Sorry for all the questions. Thanks.
Old Mar 14, 2014 | 02:41 PM
JE8154's Avatar
Originally Posted by NCRUBI2012
Okay got correction wedges. Any tips on install? High side towards TB? They are so "slippery" will this not cause a problem with springs shifting or moving around?? Do I still add the spring hold downs after? Nothing in the box. Sorry for all the questions. Thanks.
Thick side goes in the rear. Yes you can still add your coil retainers after they will help keep everything in place
Old Mar 14, 2014 | 03:35 PM
NCRUBI2012's Avatar
Thanks for quick assist.
