Extend FRONT axle breather tube 2.5 Max Travel?
Old Mar 11, 2014 | 05:32 PM
bluebear's Avatar
Default Extend FRONT axle breather tube 2.5 Max Travel?
Just did my rear and question if it's needed up front with this kit. Thanks in advance.
Old Mar 11, 2014 | 05:59 PM
bluebear's Avatar
I should mention I'm planning on disconnecting sway bars for a future run.
Old Mar 11, 2014 | 06:11 PM
karls's Avatar
Only you will know. Go flex the front axle and see if it tugs the line out of place.
Lemme cheat- yes, you need it.
Old Mar 11, 2014 | 06:33 PM
RevyJKU08's Avatar
Flexing and disco'ing with 2.5 inch lift will not affect your front breather tube much as its mounted to the frame with some slack. But does have a chance of tugging off from the diff nipple. Just be sure you have it clamped down at the diff nipple to avoid it from tugging off. I would extend all you breathers if you plan on deep diving into water/mud. That includes your tranny and transfer case.
