2" ome lift with 35" tires
Old Mar 14, 2014 | 04:23 PM
tonyaca's Avatar
Default 2" ome lift with 35" tires
Ok, I made the jump to 35" tires and I have an OME 2" lift. I know I have to trim my pinch seams and rock rails is there any thing else I have to do to run this set up? I am wondering what everybody else is doing because it looks pretty tight on the rear wheels. I still have the stock fender flares and am not opposed to trimming them.
Old Mar 14, 2014 | 06:16 PM
jstikel3's Avatar
I'm about to make this move as well, what kind of added weight do you have? Also are they the HD or LD springs? You will probably be fine for a DD but if you wheel at all I am almost certain you will need flats or trim the stock fenders.
Old Mar 14, 2014 | 06:28 PM
Xodius's Avatar
I have the hd ome lift with 35's and just barely rub in the back at full flex but I do not disconnect my sway bar. I am sure that would make a difference. Mine are also on 15's.
Old Mar 14, 2014 | 08:17 PM
TheDirtman's Avatar
You should need about 2" more bump stop with the factory fenders.
Old Mar 15, 2014 | 02:51 AM
beermantsw's Avatar
you wil nee rear bump stops if you are going to do any wheeling or you will rip your rear flares off, I know from experience
Old Mar 15, 2014 | 04:12 AM
TJJK's Avatar
MCE Flat fenders would be my call
Old Mar 15, 2014 | 07:49 AM
Xodius's Avatar
For bump stops you can always use hockey pucks. I know a lot of people that do that.
Old Mar 15, 2014 | 08:02 AM
WINGIT's Avatar
I have the 2 in OME lift on 35 in KM2's. I rubbed very little but wasn't disconnected.
Old Mar 15, 2014 | 09:12 AM
08rubie's Avatar
what year is ur jeep? i thought on the 2012's + you didn't have to trim any thing for 35's??
Old Mar 15, 2014 | 09:53 AM
olyelr's Avatar
Nothing changed since 2007, other than minor trim at rear pinch seem for some '13s and most all '14s.
