Levening kit check up
No the spacer kit. I'm wondering if they wear out over time or if anyone has any problems over time. I just wanna remove the rake and I have been wanting to do this kit for awhile. I want a long term solution, I don't want to go and replace these till I'm ready to put a proper lift on. Which at the rate I'm going could be a long time. For now it's my daily driver and I don't want to go above 33 tire. So I wanna just add a little up front for a not so stuffed look.
Coming up to one year and 33,000KM installed on my 08 JKU with 16 / 58 springs. TF puck level kit as per OP.
I'm pretty picky, and honestly, I can't see any change in the 'level', lift, or ride quality. Excellent product, very happy, the product did what it said...smack dab level.
I did take reference measurements the day it was installed, a little warmer weather and I can re-check.
Mine never wore out, these are extremely stiff pieces of polyurethane/rubber. Maybe it settled 1/16 of an inch. Your stock springs will sag before you have any problem with these TeraFlex pucks. Your factory spring isolators will "give" more than these will over time.
