Rotor Replacement
With approximately 85k miles my Jeep got its first replacement of brake pads. At the time of the service (early February of this year) I could not afford replacement rotors. There has been a very noticeable squeaking whenever I come to a stop, which I can only assume is being caused by worn out rotors. My question is there an advantage to replacing the stock brake rotors with aftermarket rotors that are described as being drilled and slotted? I do an occasional amount of off-roading, maybe once or twice every few months, so my thought was that aftermarket rotors may be better suited than would the stock. Let me know your thoughts.
I run the EBC drilled and slotted rotors with their pads. There is a definite quicker stopping ability than stock. I mainly run these to compensate for the added weight of my 34" tires and heavy bumpers ands skids. If your JK is stock there really isn't a need but "because you can" is always a good option!
I installed Power Stop drilled rotors and pads on the rear. Noticed improved breaking right away, good so far and it's been 25,000 Kms
Wool put these up front when the time is right. They were priced reasonable too, 229.00 out the door for rotors and pads. (Rear)
Anyone notice actual decreased braking ability or decreased pad life with drilled/ slotted? If you think about it, you've got less surface area to bite into (in the OE size) and all of the holes and chamfers will have an edge to wear away more or the pad than the standard slick surface.
There are also rumors (can't find the threads now) of these style rotors cracking when they're exposed to cold liquids or snow- again, due to the lack of surface area. The heat is built up in what metal is there and it's much easier to form a crack between two small holes than a solid rotor.
Fyi- I run stock rotors all around with HPS+ in the rear, OE in the front at 100k miles with pulling a 2k lb trailer (atv's on a 5x12' flat).
I'm certainly open to facts if you've got them to either confirm or deny the theory and experiences presented above. Who wouldn't want a worthwhile upgrade in their braking system?
Anyone notice actual decreased braking ability or decreased pad life with drilled/ slotted? If you think about it, you've got less surface area to bite into (in the OE size) and all of the holes and chamfers will have an edge to wear away more or the pad than the standard slick surface. There are also rumors (can't find the threads now) of these style rotors cracking when they're exposed to cold liquids or snow- again, due to the lack of surface area. The heat is built up in what metal is there and it's much easier to form a crack between two small holes than a solid rotor. Fyi- I run stock rotors all around with HPS+ in the rear, OE in the front at 100k miles with pulling a 2k lb trailer (atv's on a 5x12' flat). I'm certainly open to facts if you've got them to either confirm or deny the theory and experiences presented above. Who wouldn't want a worthwhile upgrade in their braking system?
