Oil change = check light
I've had the same code pop on and off a few times. Just was curious if there was some relation. Saw a posting on some other site with a completely different vehicle and someone said he could be using the wrong oil?? Didn't think it would matter but who knows
Here is some info for the code you have on your 2007 JK:
P0058-O2 SENSOR 2/2 HEATER CIRCUIT HIGH [Driver's side, lower]
[TABLE]
[TR]
[TD="bgcolor: white, align: center"]Possible Causes
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]O2 2/2 HEATER CONTROL CIRCUIT OPEN
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]O2 2/2 HEATER GROUND CIRCUIT OPEN
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]O2 2/2 HEATER CONTROL CIRCUIT SHORTED TO VOLTAGE
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]2/2 O2 SENSOR
[/TD]
[/TR]
[TR]
[TD="bgcolor: white, align: left"]POWERTRAIN CONTROL MODULE (PCM)
[/TD]
[/TR]
[/TABLE]
- When Monitored: Continuously during O2 heater operation with battery voltage between 10.4 and 15.75 volts.
- Set Condition: The PCM detects that the O2 sensor heater element input is above the maximum acceptable voltage. One trip fault. Three good trips to turn off the MIL.
[TABLE]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[TR]
[/TD]
[/TR]
[/TABLE]
