Rancho 9000xl adjustables wont work with my lift?
Thinking about getting the rancho adjustables for my 2door. Called Quadratec and they told me that the rancho 9000 shock wont work for my lift.
They said they make one for 0-2 inch of lift, and 4+ of lift. Since I have rk 2.5 inch coils ( 3 inch lift) the rep said they wont work.
I don't know too much about shocks, but shouldn't I be able to use the longer ones ( 4+ of lift) for my set up anyway? I read posts about longer shocks being used all the time.
I've got the 9000xl's and they've been great.
I believe this is what you're looking for. Ignore the 0-2" or 4" lift bs. I'm assuming you're running 3" or more of bump stop to fit 40's on 3" of lift.
RS999331 (front)
16.6 compressed 27.32 extended 10.7 travel
RS999332 (rear)
16.18 compressed 27.25 extended 10.43 travel
RS999331 (front)
RS999332 (rear)
RS999331 (front)
RS999332 (rear)
RS999331 (front)
RS999332 (rear)
I run 9000XLs with a RK 2.5" Max Travel. These measurements are within what RK suggests on their website. See http://www.rockkrawler.com/ProductDe...tCode=RKJK25MT. The shock tab gives you specific shock measurements and the bumpstop size you should run.
Sent from my iPad using Tapatalk HD
RS999331 (front)
RS999332 (rear)
RS999331 (front)
RS999332 (rear)
RS999331 & RS999332 with 3" of bump stop
RS999329 & RS999330 with 2" of bump stop
Give me a shout any time for forum member pricing
