After Lift and 35's---What Jack to Change Flat?
Old May 6, 2014 | 03:47 AM
FDHog's Avatar
Default After Lift and 35's---What Jack to Change Flat?
MOire than likely, my stock jack will not lift my JK high enough to change a flat after my 2.5 RK Flex and 35's.
DO you guys carry blocks of wood, or do you have a different jack? I know I can get a high lift jack.
Old May 6, 2014 | 03:49 AM
DannyMalkin's Avatar
I have a block of wood for now, getting a hi lift soon
Old May 6, 2014 | 03:56 AM
John.M's Avatar
Amazon sells a jack base that works perfectly with the stock jack. It also fits nearly I'm the rear storage area.
Old May 6, 2014 | 04:15 AM
4W-Jive's Avatar
Both. I wouldn't change a tire by use of a high lift unless I had to. I strongly prefer the vehicle supported on the axle. Hi lift for recovery or odd scenarios, block of wood for factory jack.
SpicedCrusher's Avatar
I would never use a Hi Lift for changing tires unless it was an emergency. I can have my 35" tire completely off after lifting the axle with my factory jack before I could have it off the ground enough with my Hi-Lift. I place my factory jack under the control arm or shock mounting points.
Old May 6, 2014 | 04:21 AM
JKZinger's Avatar
Just get one of those plastic Hi Lift jack bases. Works perfect on any surface and stores nicely in the jeep.
Old May 6, 2014 | 04:30 AM
DunnyBunny's Avatar
JK-Forum Ambassador
Exactly. I have no issues with my factory jack and no block or stand.
FDHog's Avatar
Thanks guys!
Old May 6, 2014 | 07:48 AM
Sahara Lee's Avatar
I have one of these orange things:
AEV Conversions 40306002AA - AEV Jack Base for 07-14 Jeep® Wrangler & Wrangler Unlimited JK - Quadratec
I could have used a block of 4x4 but this thing fits in the storage area, holds my Gorilla lug key, and doesn't give me splinters.
NEVER us a HI-Lift to change a tire UNLESS you have no other choice. The Hi-Lift is not a safe jack for changing tires. It is meant to be a recovery tool only.
Change you tire on a hard, flat, level surface using a scissors or bottle jack under your axel.
Old May 6, 2014 | 07:54 AM
DunnyBunny's Avatar
JK-Forum Ambassador
Originally Posted by Sahara Lee
I have one of these orange things: AEV Conversions 40306002AA - AEV Jack Base for 07-14 Jeep® Wrangler & Wrangler Unlimited JK - Quadratec I could have used a block of 4x4 but this thing fits in the storage area, holds my Gorilla lug key, and doesn't give me splinters. NEVER us a HI-Lift to change a tire UNLESS you have no other choice. The Hi-Lift is not a safe jack for changing tires. It is meant to be a recovery tool only. Change you tire on a hard, flat, level surface using a scissors or bottle jack under your axel.
Overpriced though as with a lot of AEV stuff. $30 is a better price point
