Driveshaft Causing noise in 4 wheel drive? Help!
Hi, I have a 2008 JK 4DR, with a 4" suspension lift and some 33's on it. Honestly the jeep doesn't see much off roading due to where i live. A year ago I was dealing with the "Death Wobble" and it was BAD.. I had taken it in a few times, had it balanced and re-aligned, nothing solved the issue. I then put a dual steering stabilizer on it and haven't had the issue again. "Knock on wood".
Over the winter I was having an issue with the 4 wheel drive, every time I engaged 4 High, when I accelerate there is a continuous clicking noise from the front end. I also had a coolant leak and I couldn't figure out where it was coming from. I took my jeep in to the dealer yesterday, no longer under warranty, and they said I have a blown gasket in my intake manifold and the noise coming from the 4 wheel drive is from a wheel bearing in my driver side wheel. They quoted me $800. I thought it was strange about the bearing because it doesn't make sense to only make the noise when in 4 wheel drive.
I called them today to see if it was done, he told me it is done, however the bearing replacement didn't solve the issue. Luckily enough they did not charge me for the bearing considering it didn't solve the issue, and they charged me $365. However, they then told me that my front drive shaft needs to be replaced because that it causing the noise i'm hearing, they said my u-joints were not the issue either.
I'm curious if anyone has ever had the same issue? Is there a chance my drive shaft was affected during my death wobble stage? I'm personally not a technician though I am capable of smaller tasks when it comes to auto repairs and I have access to a shop and lift. Is this something I could change on my own or am I better off taking it into a shop? Also, i'm curious if you think the drive shaft is causing this noise or if it is something else? Any insight would be much appreciated!
I will be out of town over the weekend, so I won't be able to check any responses till Monday. Again, I appreciate your help!
Honestly all I can think is that something has fallen down on the front driveshaft. Because that's the only thing spinning in 4 that's not in 2wd. Look up under and see if something is touching the front drive shaft.
Your driveshaft and death wobble are likely unrelated. At 4" of lift if your still running the stock driveshaft it was doomed eventually anyways. As for the death wobble the stabilizer is a bandaid to a problem most likely related to your trackbar as I understand it I've never dealt with it myself
You're driveshaft is on its way out .and it always spins but there's no torque to it unless you're in four-wheel-drive.put it in low and give it gas it will click bad . Mine went to so did rear
the
Boot over the slip joint isn't a big deal. Where I'd bet a lot of money is the rzeppa joint at the transfer case on the front driveshaft has failed.
This joint = no real big deal
This is the big deal and a 4" of lift, even a pavement pounder, will eventually fail:
Sent from some string and a few tin cans.
