A different gear tire question
Old May 12, 2014 | 06:52 PM
rj'sjeep's Avatar
Default A different gear tire question
I have a 08 4dr rubicon with 4:10 gears and auto I have researched the charts until i dream numbers, My question is if I go with a 35 s tire nominally 34.4 " what will my rpm be on a flat freeway at 75 ,mph. how can you determine it the rpm for different speeds.
Who is running 35/s without changing gears ratios? how bad is This only applies to 3.8 auto rubicons with 4:10 gears .. Thanks
Old May 12, 2014 | 07:08 PM
jaker t5's Avatar
It's doable just try it , if you don't like it then regear
I ran 35s with 4.10 for a few years and didnt drive me nuts until I went 37s and knew I had to regear and man what difference if I knew what I know now I would have regear with the 35s
I just re read your post I don't have a rubi if that matters to you
Old May 12, 2014 | 07:12 PM
planman's Avatar
Forum Tech Advisor
Transmission Ratio RPM
Enter R&P Ratio, Tire Height, Speed (mph), and Transmission Ratio, then click Solve to calculate RPM
http://www.ringpinion.com/Calculators/Calc_RPM.aspx
The actual tire size will be less than 34.4". It will probably be 33.75", or at most 34".
Your 4th gear transmission ratio is 0.69.
Since you have a Rubi, you want 5.38 gears. They will put you between 2751-2776 rpm at 75 mph. You'll get better fuel economy because your engine will produce enough power to avoid frequent transmission downshifting.
If you live at sea level, don't have a heavy rig, and don't drive hills or mountains, you can get by with 5.13s. That would put you at about 2624-2647 rpm at 75 mph.
