2009 rear wheel end play
So i'm completting to process of doing a gear swap but for the life of me I can't figure this one out. Both the right and left wheels have about 1/8" play at the outer end. One side has new bearing and seal, while the other was untouched but both have play
Make sure the 4 bolts on each retainer plate are tight.
See if you can get an actual measurement of the play. I'll compare it to what mine has.
