anyone ever remove abs module?
Old May 25, 2014 | 01:24 PM
mpthompson84's Avatar
Default anyone ever remove abs module?
I'm trying to remove my ABS module to take it in for repair but I can't for the life of me figure out how to get the whole unit unbolted from the engine bay so I can access the torque bolts on the back to remove it from the hydraulic unit. There is a bolt on the side which is easy to remove but it looks like there are two nuts underneath the unit you have to access some how to remove it. I'm about to throw in the towel here. Anyone ever done this or know of a writeup up for the Jk? ?
Old Mar 29, 2016 | 08:12 PM
Vegas-JK's Avatar
How did you end up fixing your ABS issue?
Old Mar 30, 2016 | 05:20 AM
Rednroll's Avatar
I never removed mine, but did try to move it out of the way when replacing my MC. Unfortunately, I had the same problem trying to figure out how to remove it. I was able to work around it without moving it, so gave up.
However, here's a picture of the bottom of the ABS module, which should give you some insight of what's actually securing it from the bottom. It looks like after you remove the top screw and brake line connections, then some prying might be in order to get it to pop out. Looks like a rubber grommet on the end of a bolt is securing it to body.
Old Mar 30, 2016 | 05:35 AM
Rednroll's Avatar
I read your other post, of the dealer wanting $1200 to replace both ABS modules. Sounds like you've been working on this for awhile.
I would do the work yourself. You're looking at about a $300 for parts repair.
ABS module (P/N:68030936AB)
New Mopar Anti Lock Brakes ABS Module 2008 2009 Jeep Wrangler 68030936AB | eBay
Here's where I get all my OEM replacement parts. $165 new
http://www.moparpartsdiscounted.com/...8030936AB.html
ABS Pump
ABS1988 2008 2009 08 09 Jeep Wrangler ABS Pump Module P52126282AC | eBay
