Transfer case front output shaft seal leaking
Posted over at JKO, but figured I'd ask here too just incase.
Today, I pulled my front drive shaft today to replace the front u-joint on it. It had been making a chirping / squeaking noise so I figured I'd take the 15 minutes and swap it out.
What I saw on my transfer case worried me. It looks like the out put shaft seal is leaking. I pulled the yoke to make sure it wasn't leaking past the splines, but the inside of the yoke was dry. So guess that leaves the seal.
I did some searching and I couldn't find anyone who has done a write up on how to replace the front output shaft seal yet. It looks simple enough, just pry the old seal out and press in a new one. What I don't know, is how to hammer or press the new seal in. There's not a lot of room when the transfer case mounted (as I'd rather not pull it out completely), so swinging a hammer doesn't look like it'll fit.
Are there any special tools or tricks for replacing the seal?
Here's a picture of the leak.
Thanks!
Thanks!
