AEV snorkel + Rugged Ridge Hurricane flat fender flares
Old May 28, 2014 | 07:13 AM
Homme's Avatar
Default AEV snorkel + Rugged Ridge Hurricane flat fender flares + Smittybilt light brackets
Supermen!
Need your advice.
Do they fit each other?
If there is already info, pls write link.
Thanks a lot in advance and good summer to you!
Last edited by Homme; May 30, 2014 at 10:13 PM. Reason: One more connected detail I had to change
Old May 28, 2014 | 09:52 PM
Homme's Avatar
Reply from AEV
"Thank you for contacting AEV. Unfortunately our snorkel was designed to work with the factory fender flairs. We have not verified fitment with other companies flairs but I can see where there could be interference issues since most aftermarket fender flairs sit higher on the Jeep to increase tire clearance. The increased height sounds like what is causing your issues. Unfortunately I do not have a solution for this issue other than re-installing the factory fender flairs. I have seen where customers have modified aftermarket fender flairs to work with our snorkel but I would not be able to advise you on what is needed or if the modifications will affect the integrity of your aftermarket fender flair. I would not recommend modifying the snorkel, heating up and changing the form may affect the integrity and cause the snorkel to leak. Modifications to the snorkel will also void the AEV warranty for the snorkel."
Old May 29, 2014 | 02:09 AM
Homme's Avatar
It could be better if I was informed that AEV snorkel only for stock fender flares in advance.
I warmed it and changed form of it. After that I installed it without sharp instruments.
Old May 29, 2014 | 06:10 AM
KnappsJKU's Avatar
Originally Posted by Homme
It could be better if I was informed that AEV snorkel only for stock fender flares in advance. I warmed it and changed form of it. After that I installed it without sharp instruments.
Did you have to cut the hood or body ?
Old May 29, 2014 | 06:21 AM
Homme's Avatar
http://www.quadratec.com/Assets/Installation/168416.pdf
Old May 29, 2014 | 08:37 AM
KnappsJKU's Avatar
Thanks I don't have the balls to do that yet though haha
Old May 30, 2014 | 07:22 PM
Matthewd5's Avatar
Well I guess that made up my mind, I was thinking about getting an AEV snorkel just as an insurance policy against hitting a deep hole and hydralocking it
I've got the Bushwacker flares
Matthew
Old May 30, 2014 | 10:06 PM
Homme's Avatar
Originally Posted by Matthewd5
Well I guess that made up my mind, I was thinking about getting an AEV snorkel just as an insurance policy against hitting a deep hole and hydralocking it I've got the Bushwacker flares Matthew
As I said it was not difficult to change the form of it a little after warming.
Old May 30, 2014 | 10:22 PM
Homme's Avatar
Please also be informed that standard Smittybilt light bracket from snorkel side is also should be modified or changed. I did the following.
1. Short extension bars were made
2. Sandblasting
3. Powder painting
4. Additional bolts were bought
ID:	556725   Click image for larger version
ID:	556726   Click image for larger version
ID:	556727   Click image for larger version
Old Jun 9, 2014 | 06:01 AM
Homme's Avatar
Final view
ID:	558577   Click image for larger version
ID:	558578   Click image for larger version
