These wheels will fit... right?
Old May 30, 2014 | 01:16 AM
brah's Avatar
Default These wheels will fit... right?
Got a 2014 JK 2d sport, bone stock- no spacers, no lift.
Need to confirm that these will fit without rubbing the fenders/calipers.
Level 8 Tracker
15X8 5-127 -19MTB
Goodyear Wrangler DuraTrac
33X12.50R15C2 108Q W
(If you have this combo, please post some pics!)
Old May 30, 2014 | 01:21 AM
Softtailfreek's Avatar
I was running 15 inch rims and 35's with no lift but cut my fenders and pinch seam. My guess is you will rub with the 12.5 tire with steering at full lock. I've since put on a 2.5 inch lift. If you put on a leveling kit that would help
Old May 30, 2014 | 01:30 AM
35s with no lift and got rid of cut fenders and added Bush wacker flats
Old May 30, 2014 | 03:03 AM
Yellowfin's Avatar
Yes...with a 12.50 tire, you'll rub the frame a little when turning full lock. Can either add spaces or adjust your steering stops to compensate. I'm running 37x12.50-17 on 2.5" of lift and mind rub at full lock. Doesn't bother me because it's not enough to notice until you look in the wheel well and see the rub marks on the frame.
Hope that helps.
Old May 30, 2014 | 09:01 AM
brah's Avatar
Thanks for the responses guys.
Talked to a DTD rep and he said that they will not fit on a sport, but will on a rubi.
Can anybody confirm/deny whether they fit on a Sport S stock suspension?
Old May 30, 2014 | 09:31 AM
I have a 4 door sport and they fit but rubbed at full lock. Not sure why they would fit a rubi and not a sport
Old May 30, 2014 | 12:45 PM
familytime's Avatar
JK Forum Regional Rep
Unless JK's changed since 2007 35x12.50-17 fit with no rub.
Old May 30, 2014 | 12:58 PM
Goeagles88's Avatar
What is the backspacing of the wheel? If it is at least 4.5" you should be fine. With 12.5" wide tires, you will rub on a lot of stuff if the backspacing isn't right.
Old May 30, 2014 | 01:12 PM
brah's Avatar
-19 offset, so about 3.75'' of backspacing.
Anybody have this set up? Chime in!
Old May 31, 2014 | 01:01 AM
brah's Avatar
Love the look of 35s, sick jeep
I'm not looking to lift anytime soon, so gonna have to go with these 33s. hopefully the rims fit an the tires don't rub too much as a DD
