Speed sensors, any tips?
Old May 31, 2014 | 12:05 PM
Brightwhite's Avatar
Default Speed sensors, any tips?
I just installed my rear chromoly axle shafts, but I'm having trouble getting the speed sensor wire end reconnected to the actual speed sensor. It was a B$&;@!H to get off after sliding the red tab out, now when I slide them on and press the red tab in I can still remove them by had with a little tug. Any tips on getting these suckers back on correctly?
Maybe I stripped them out somehow and broke something? I didn't hear anything pop or break when I finally got them disconnected.
Also my ABS and traction control lights are on, assuming that is due to the speed sensors not attached properly?
Old May 31, 2014 | 03:34 PM
Gieringer11's Avatar
I had the same problem use a little bit of superglue and you're good to go super glue on the end hold it for five minutes drinking beer move onto the next one
