Will 35s fit on a 2d with JKUR suspension?
You would be better off just adding a spacer lift or some slightly longer coils like the 1.5 rock crawler or some from Ebach. You get more height from the 18/60 coils due to a higher coil rate not a longer coil resulting in a rougher ride. You will still need wheel adapters to run a 35"x12.5" tire.
