fixed my gangsta lean...
Old Jun 4, 2014 | 06:25 PM
JayswranglerX's Avatar
Default fixed my gangsta lean...
Ok guys, after installing a 3.5" MC lift I had the pass. side lean to the tune of about 3/4".
Never noticed it before the new springs.
After looking over everything from proper spring seating to isolator pad centering etc.. I finally gave up.
While pondering this one day over a beer of course, I thought something had to be causing it that wasn't like that before.
Well the only thing I could think of that I didn't triple check was the front sway bar links.
After taking apart during initial lift install to clean and lube them up ( RK adjustables I had on previous lift ) I put them back together with one side 3/4" longer than the other.
That's what a full Saturday of installing the lift myself and being completely shot and half retarded by the time I was done got me.
After lengthening the pass. side to match the driver side ( duh )
It now sits dead level.
Just something to check out as a possible cause for the guys still sporting the gangsta
Sent from my LG-LS980 using JK-Forum
Old Jun 4, 2014 | 09:02 PM
phuggit's Avatar
Lol. I was pretty punch drunk after installing my lift too. Neck and back hurt like a sumbiotch for a couple days. Thanks for posting the info.
Old Jun 5, 2014 | 05:32 AM
No problem...always a PITA to figure these things sometimes
Old Jun 7, 2014 | 06:08 AM
bfschor's Avatar
So now how does it sit when you're in the drivers seat? I've gotta lean when I'm not in it, but as soon as I get in, it levels out.
It bugs me really bad. I thought if I try fixing it, it'd just go back to leaning once I got in it. (I'm only 200 lbs).
Here's another thing...so since it's level once I get in it, as soon as a passenger gets in, the lean comes back.
I've never seen a vehicle so sensitive to weight.
Old Jun 7, 2014 | 02:34 PM
I know man it's nuts these things are like this.
In my case, as soon as I figured out I was a dumbass and set the links wrong it went level and stays level even with my 215lbs. In it alone.
Passenger doesn't affect it leaning to the that side again.
Old Jun 7, 2014 | 02:48 PM
bfschor's Avatar
Originally Posted by JayswranglerX
I know man it's nuts these things are like this. In my case, as soon as I figured out I was a dumbass and set the links wrong it went level and stays level even with my 215lbs. In it alone. Passenger doesn't affect it leaning to the that side again. Sent from my LG-LS980 using JK-Forum
Hmmm.....I don't have adjustable sway bar links, so I don't think that would be my problem? My lift is a 2.5".....not as high as yours, so that's prob why I didn't get any with my kit.
I'm glad you fixed yours!
Old Jun 7, 2014 | 03:11 PM
Yeah that takes that variable out of it.
But like many have said, theirs came with it from the factory!
Chrysler quality for ya.
It's tough when the lean can be changed by having just a driver or both a driver and passenger.
If it never went away even with
Just you driving I'd throw a spacer at that corner but not really worth it if it comes back when you have a passenger
